pi@raspberrypi /opt/owfs/bin $ ls
owdir owexternal owget owmon owread owtap
owexist owftpd owhttpd owpresent owserver owwrite
går alltså inte köra sudo /opt/owfs/bin/owfs --i2c=ALL:ALL --allow_other /mnt/1wire/ som det står i guiden på
http://wiki.temperatur.nu/index.php/OWF ... version%29
Compile-time options:
USB is DISABLED
I2C is enabled
W1 is enabled
Parallel port DS1410E is enabled
Zeroconf/Bonjour is enabled
Debug-output is enabled
Profiling is DISABLED
Tracing memory allocation is DISABLED
1wire bus traffic reports is DISABLED
Module configuration:
owlib is enabled
owshell is enabled
owfs is DISABLED
owhttpd is enabled
owftpd is enabled
owserver is enabled
owexternal is enabled
ownet is enabled
ownetlib is enabled
owtap is enabled
owmon is enabled
owcapi is enabled
swig is DISABLED
owperl is DISABLED
owphp is DISABLED
owpython is DISABLED
owtcl is DISABLED
Körde sudo apt-get install automake autoconf autotools-dev gcc-4.7 libtool libusb-dev libfuse-dev swig python2.7-dev tcl8.5-dev php5-dev i2c-tools igen så blev det bättre resultat.
En restart innan sudo /opt/owfs/bin/owfs --i2c=ALL:ALL --allow_other /mnt/1wire/ löste DEFAULT: owlib.c:(57) No valid 1-wire buses found
