How to pair Vriddimmer, ZigBee to deconz/Home assistant
martincb
Inlägg av martincb »
Hi,
I do not fully understand how to pair my deconz conbee II with the Sunricher dimmer.
Vriddimmer, ZigBee https://www.m.nu/dimmer-zigbee/vriddimmer-zigbee
I followed this instruction below, but it did not really work. I used the add new switch on the phoscon app on the home automation webpage.
But how close does the Conbee have to be to the Sunricher dimmer when pairing? Because the server where the conbee is connected is not so easy to move.
Step 3: Reset power of the device
from master breaker to set it into
network pairing mode (connected
light flashes twice slowly), 15
seconds timeout, repeat this step
Thanks in advance! I also have the ikea gateway that might be possible to pair to the Sunricher.
fixarsorken
Re: How to pair Vriddimmer, ZigBee to deconz/Home assistant
Inlägg av fixarsorken »
Hi,
Did you ever get this sorted out? I just installed a Sunricher Zigbee-dimmer and I can't get it to pair using the Phoscon app.
I've tried pairing both as light and switch. I tried factor reset several times.
Thanks in advance!
Jonas
Skickat från min LE2123 via Tapatalk
