Fler sensorer i ett fönster
CirruZZ
Master Moderator
Re: Fler sensorer i ett fönster
Inlägg av CirruZZ »
Har du kört guiden http://wiki.temperatur.nu/index.php/RRDtool_HowTo ? Loggar du fler sensorer redan?
jed
Inlägg av jed »
Mitt skript grafar 4 källor och skapar grafer för 24h, 1v, 1m, 1å och 10å. Borde vara hyfsat enkelt att förstå vad du ska ändra, säg till annars så förklarar jag (tips: kolla på mt $path_* my $rrd_* och DEF).
#!/usr/bin/perl
use RRDs;
my $path_24h     = "/var/www/ha/graphs/temp_day.png";
my $path_week    = "/var/www/ha/graphs/temp_week.png";
my $path_month   = "/var/www/ha/graphs/temp_month.png";
my $path_year    = "/var/www/ha/graphs/temp_year.png";
my $path_10y     = "/var/www/ha/graphs/temp_10y.png";
my $rrd_garage   = "/var/ha/rrddata/garage_outside_temp.rrd";
my $rrd_storage  = "/var/ha/rrddata/garage_inside_temp.rrd";
my $rrd_grund    = "/var/ha/rrddata/basement_temp.rrd";
my $rrd_playroom = "/var/ha/rrddata/playroom_temp.rrd";
my $time_curr   = time();
my $time_day    = $time_curr - 86400;     	# set end time to 24 hours ago
my $time_week   = $time_curr - 604800;    	# 1 week ago
my $time_month  = $time_curr - 2419200;   	# 1 month ago
my $time_year   = $time_curr - 29030400;  	# 1 year ago
my $time_10y    = $time_curr - 290304000;	# 10 years ago
generate_graph ($path_24h,   $time_curr, $time_day);
generate_graph ($path_week,  $time_curr, $time_week);
generate_graph ($path_month, $time_curr, $time_month);
generate_graph ($path_year,  $time_curr, $time_year);
generate_graph ($path_10y,   $time_curr, $time_10y);
sub generate_graph
	my $path       = shift;		# Path to the generated graph
	my $time_end   = shift;		# End time
	my $time_start = shift;		# Start time
	RRDs::graph "$path",
			"--start= $time_start",
			"--end= $time_end",
			"--title= Temperaturer",
			"--height= 300",
			"--width= 500",
			"--vertical-label= °C",
			"-E",
	      "DEF:Garage=$rrd_garage:garage_outside_temp:AVERAGE",
			"COMMENT:\t\t\t\t\tNu     Medel    Max    Min\\n",
			"HRULE:0#00FF00",
	      "LINE2:Garage#00FF00:Garage, utomhus\t\t",
			"GPRINT:Garage:LAST:%6.1lf",
			"GPRINT:Garage:AVERAGE:%6.1lf",
			"GPRINT:Garage:MAX:%6.1lf",
			"GPRINT:Garage:MIN:%6.1lf\\n",
	      "DEF:Storage=$rrd_storage:garage_inside_temp:AVERAGE",
			"HRULE:0#0000FF",
	      "LINE2:Storage#0000FF:Forradet\t\t\t",
			"GPRINT:Storage:LAST:%6.1lf",
			"GPRINT:Storage:AVERAGE:%6.1lf",
			"GPRINT:Storage:MAX:%6.1lf",
			"GPRINT:Storage:MIN:%6.1lf\\n",
	      "DEF:Playroom=$rrd_playroom:playroom_temp:AVERAGE",
			"HRULE:0#0F0F0F",
	      "LINE2:Playroom#0F0F0F:Lekrummet\t\t\t",
			"GPRINT:Playroom:LAST:%6.1lf",
			"GPRINT:Playroom:AVERAGE:%6.1lf",
			"GPRINT:Playroom:MAX:%6.1lf",
			"GPRINT:Playroom:MIN:%6.1lf\\n",
	      "DEF:BasementTemp=$rrd_grund:basement_temp:AVERAGE",
			"HRULE:0#FF0000",
	      "LINE1:BasementTemp#FF0000:Krypgrund\t\t\t",
			"GPRINT:BasementTemp:LAST:%6.1lf",
			"GPRINT:BasementTemp:AVERAGE:%6.1lf",
			"GPRINT:BasementTemp:MAX:%6.1lf",
			"GPRINT:BasementTemp:MIN:%6.1lf\\n";
	my $err=RRDs::error;
Reultatet blir en sån här graf:
God jul!
CirruZZ
Master Moderator
Inlägg av CirruZZ »
Om du utgår ifrån guiden och ändrar
RRDs::graph "/var/www/graph_temp.png",
			"--start= $start_time",
			"--end= $cur_time",
			"--title= Temp ute",
			"--height= 300",
			"--width= 500",
	      "DEF:OutsideTemp=/home/anders/rrddata/outside_temp.rrd:outsidetemp:AVERAGE",
			"COMMENT:\t\t\t\tNu     Medel    Max    Min\\n",
			"HRULE:0#0000FF",
	      "LINE2:OutsideTemp#0000FF:Ute\t\t\t",
			"GPRINT:OutsideTemp:LAST:%6.1lf",
			"GPRINT:OutsideTemp:AVERAGE:%6.1lf",
			"GPRINT:OutsideTemp:MAX:%6.1lf",
			"GPRINT:OutsideTemp:MIN:%6.1lf\\n";
till
			"--end= $cur_time",
			"--height= 300",
			"--width= 500",
             "DEF:InsideTemp=/home/anders/rrddata/inside_temp.rrd:insidetemp:AVERAGE",
			"HRULE:0#0000FF",
			"GPRINT:OutsideTemp:MIN:%6.1lf ,
	      "LINE2:InsideTemp#FF00FF:Ute\t\t\t",
			"GPRINT:InsideTemp:LAST:%6.1lf",
			"GPRINT:InsideTemp:AVERAGE:%6.1lf",
			"GPRINT:InsideTemp:MAX:%6.1lf",
			"GPRINT:InsideTemp:MIN:%6.1lf\\n";
Om du kollar så ser du att det bara är tillagd en källa som heter InsideTemp och att den sen även ritas ut med LINE2 och lite värden från den visas.
jed
Inlägg av jed »
Du glömde ändra namn på rrdfilerna, alla hette samma sak så du uppdaterade bara indoortemp.
Har ändrat din fil:
get_temp.txt
(842 Bytes) Nerladdad 352 gånger
jed
Inlägg av jed »
Bra att det funkar, gott nytt år! :)
