Hittade lite mer:
http://www.maxbotix.com/Ultrasonic_Sens ... ensors.htm
Funderar dock på:
"Pin 4-SDA (I2C Data)– This is the data line for I2C communications. The I2CXL-MaxSonar-WR series operate as
I2C slave devices, supporting 7-bit addressing, with a default shipped address of hexadecimal 70 (decimal 112). This
corresponds to an equivalent 8-bit address of E0 (decimal 224).
Pin 5-SCL (I2C Clock)- This is the clock line for I2C communications. The I2CXL-MaxSonar-WR series supports I2C
clock frequencies up to 100kHz. Clock stretching must be supported by the master device for read requests with a clock
speed above 25kHz."
M.nu:s i2c kort har ej SCL ?
