Men nu fungerar det.
Nu när det kommer upp så minns jag att i HOWTOn till RPin så står (stod iaf) båda alternativen med.
Tackar så mycket.
/Lenny
Compile-time options:
USB is DISABLED
sudo apt-get install pkg-config
#:/usr/src/owfs-3.1p5$ sudo ./configure --enable-debian --enable-usb --enable-owfs --enable-owpython
Deployment location: /opt/owfs
USB is enabled
AVAHI is DISABLED
I2C is enabled
W1 is enabled
Parallel port DS1410E is enabled
FTDI (LinkUSB) is DISABLED
Zeroconf/Bonjour is enabled
Debug-output is enabled
Mutexdebug is enabled
Profiling is DISABLED
Tracing memory allocation is DISABLED
Module configuration:
owlib is enabled
owshell is enabled
owfs is enabled
owhttpd is enabled
owftpd is enabled
owserver is enabled
owexternal is enabled
ownet is enabled
ownetlib is enabled
owtap is enabled
owmon is enabled
owcapi is enabled
swig is DISABLED
owperl is DISABLED
owphp is DISABLED
owpython is DISABLED
owtcl is DISABLED
unit tests are DISABLED
