Allt ser ok ut förutom att route tar lite lång tid på sig.
Sedan så verkar WPA-infon ha tappats och det går inte att lägga till den på nytt!
/etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.1.200
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.1.1
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.1.201
network 192.168.1.0
gateway 192.168.1.1
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
domain lan
search lan
nameserver 192.168.1.1
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="[borttaget]"
psk="[borttaget]"
proto=WPA
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
ifconfig ger
eth0 Link encap:Ethernet HWaddr b8:27:eb:c3:74:95
inet addr:192.168.1.200 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:792 errors:0 dropped:0 overruns:0 frame:0
TX packets:394 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:129688 (126.6 KiB) TX bytes:47569 (46.4 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr 00:0f:13:05:34:58
Tips?
/Mats
