Hjälp med rörelsevakt =)
Postat: 03 jan 2015, 19:41
Tjo
Jag ha hittat denna scen som jag vill ska funka med ett vägguttag , när garage dörren öppnas och rörelsen blir aktiv skall lampan tändas och släckas efter en viss tid.
%% properties
28 value
%% globals
--167 = PIR for movement detection
--Scene purpose
--IF PIR detects movement then turn on dimmer and turn it off 5 minutes.
-- If new movement detected during the 5 minute period set the timer for 5 minutes
local sceneId = 62 --ID of this scene, used to detect number of instances run
local timerEndTime = 2 --Minutes to keep the lamp turned on after PIR detects movement
local timer = "timer" --Name of global variabel to control the timer
local timerValue = fibaro:getGlobalValue(timer) --Current value of global variabel for timer
local triggerValue = fibaro:getValue(28, "value") --Get PIR value that activated this scene
local lights = 27 --light to be controlled by this scene
fibaro:debug("start, timer = " .. timerValue .. " lights = " .. fibaro:getValue(lights, "value") .. " ,triggerValue = " .. triggerValue)
if (fibaro:getValue(lights, "value") == "0" and triggerValue == "255") then
--If starts if lights off and PIR detected movement
fibaro:call(lights, "setValue", tostring(dimmerValue)) --Turn lights on
fibaro:setGlobal(timer, timerEndTime) --Set global variabel for timer
while (fibaro:getGlobalValue(timer) ~= "0") do
--Loop used to control timer, each loop 1 minute and continues
--as long as timer variabel isn't 0
timerValue = tonumber(fibaro:getGlobalValue(timer)) --Get current value of global variabel timer
fibaro:setGlobal(timer, timerValue-1) --Decrease global variabel for timer with 1 minute
fibaro:debug("Loop - timer = " .. fibaro:getGlobalValue(timer))
fibaro:sleep(60*1000) --Wait 1 minute
end
fibaro:call(lights, "turnOff") --Turn lights off
elseif fibaro:countScenes(sceneId) > 1 then
--if scene is already running the set timer to 2 minutes
fibaro:setGlobal(timer, timerEndTime) --set global variabel for timer to 2 minutes
fibaro:debug("New instance, totalt = " .. fibaro:countScenes(sceneId))
end
fibaro:debug("End, instances = " .. fibaro:countScenes(sceneId))
Men den gör inte som jag vill , om jag kör scenen får jag följande.
[DEBUG] 18:41:17: start, timer = lights = 0 ,triggerValue = 255
[ERROR] 18:41:17: line 30: attempt to perform arithmetic on local 'timerValue' (a nil value)
%% properties
28 value
%% globals
--Scene purpose
end
end
