Har skickat följande till fibaros support, men ännu inte fått svar. Jag tror min plug är trasig, men det kan ju ockå vara SBS. Vad tror ni?
I've just bought a Fibaro wall plug which I'm using together with a Zipabox.
My issue is that if the plug is unpowered (unplugged) and then powered again it never shows up as online in my Zipabox. This issue does not happen with any of my other devices.
If the plug is unplugged while in off state and then immediately reinserted the device fashes green one time and is operating normally.
If the plug is unplugged while in on state and then reinserted in a plug it always flashes red one time and does not communicate with the controller. Plug need to be reset and readded to z-wave network.
The device works fine if the wall plug is reset (by holding B button), readded by the controller and never is unplugged. I've tried this sequence several times now but as soon as the device is unplugged it seems to loose its memory.
