Jag kör Domoticz 3.8153 på en Raspberry Pi 3 med Z-stick och detta är konfigurationen för en av mina sömniga SP103:
<Node id="15" name="Rörelse gårds" location="" basic="4" generic="32" specific="1" type="Routing Slave" listening="false" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="3" query_stage="CacheLoad">
<Manufacturer id="60" name="Everspring">
<Product type="101" id="1" name="SP103 PIR Motion Sensor" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" setasreport="true">
<Instance index="1" />
</CommandClass>
<CommandClass id="48" name="COMMAND_CLASS_SENSOR_BINARY" version="1" request_flags="4" innif="true">
<Value type="bool" genre="user" instance="1" index="0" label="Sensor" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<SensorMap index="0" type="50" />
<SensorMap index="0" type="205" />
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
<Value type="byte" genre="config" instance="1" index="1" label="ON Phase Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="127" value="1">
<Help>Phase Level of ON Command The Configuration parameter that can be used to adjust the phase level of ON command is transmitted is Configuration Parameter # 1. This parameter can be configured with the value of 0 through 127. Value 0: Set Device OFF(0x00) Value 1-99: Set Device On (1-99) Value 100-127: Set Device On to the last phase (0xFF) Note: 0xFF means the device will be on to the last phase before the device was turned off. Information reproduced from: http://www.techstyleuk.co.uk/index_files/sp103_manual.pdf</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="3" label="Power Saving" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="127" value="0">
<Help>Enabling/Disabling Power Saving Function (for testing) When no movement has been detected for 10 seconds, the SP103 will enter the power saving mode. It can be disabled or enabled power saving function by setting Configuration Parameter # 3. This parameter can be configured with the value of 0 through 127, where 0 means power saving being enabled and others mean power saving being disabled. PS : As long as the batteries have been refitted, the Detector will enable the power saving function automatically. Information reproduced from: http://www.techstyleuk.co.uk/index_files/sp103_manual.pdf</Help>
</Value>
</CommandClass>
<CommandClass id="113" name="COMMAND_CLASS_ALARM" version="1" request_flags="2" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
<Value type="byte" genre="user" instance="1" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="17" />
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="128" name="COMMAND_CLASS_BATTERY" version="1" request_flags="4" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Battery Level" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="100" />
</CommandClass>
<CommandClass id="132" name="COMMAND_CLASS_WAKE_UP" version="1" request_flags="2" innif="true">
<Value type="int" genre="system" instance="1" index="0" label="Wake-up Interval" units="Seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="14400" />
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
<Associations num_groups="1">
<Group index="1" max_associations="5" label="Motion" auto="true">
<Node id="1" />
</Group>
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.28" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.04" />
</CommandClass>
</CommandClasses>
</Node>
