"--right-axis 1:0,"Har provat olika placeringar i koden utan resultat. Har även provat med ett "=" innan värdet (som verkar behövas ibland) men inget funkar.Graph error: unknown option '--right-axis 1:0'
function create_graph($output, $start, $end, $title) {
$options = array(
"-E",
"-l 0",
"--start", $start,
"--end", $end,
"--title=$title",
"--vertical-label=Grader celsius",
"--height= 400",
"--width= 800",
"DEF:Ute=/home/hellgun/rrddata/temp_ute.rrd:ute:AVERAGE",
"DEF:Inne=/home/hellgun/rrddata/temp_inne.rrd:inne:AVERAGE",
"DEF:UteMin=/home/hellgun/rrddata/temp_ute.rrd:ute:MIN",
"DEF:UteMax=/home/hellgun/rrddata/temp_ute.rrd:ute:MAX",
"DEF:InneMin=/home/hellgun/rrddata/temp_inne.rrd:inne:MIN",
"DEF:InneMax=/home/hellgun/rrddata/temp_inne.rrd:inne:MAX",
"VDEF:mintimeout=UteMin,MINIMUM",
"VDEF:maxtimeout=UteMax,MAXIMUM",
"VDEF:mintimein=InneMin,MINIMUM",
"VDEF:maxtimein=InneMax,MAXIMUM",
"COMMENT:\t",
"HRULE:0#FF00FF",
"LINE1.5:Ute#0000FF:Ute\tSenast\\:\t",
"GPRINT:Ute:LAST:%6.1lf\t\t\t\t\t",
"LINE1.5:Inne#FF0000:Inne\tSenast\\:\t",
"GPRINT:Inne:LAST:%6.1lf\\n",
"COMMENT:\t\t\tMedel\\:\t",
"GPRINT:Ute:AVERAGE:%6.1lf\t\t\t\t",
"GPRINT:Inne:AVERAGE:%6.1lf\\n",
"COMMENT:\t\t\tMax\\:\t\t",
"GPRINT:UteMax:MAX:%6.1lf",
"GPRINT:maxtimeout:(%d/%m %H\\:%M):strftime",
"COMMENT:\t\t\t\tMax\\:\t\t",
"GPRINT:InneMax:MAX:%6.1lf",
"GPRINT:maxtimein:(%d/%m %H\\:%M):strftime",
"COMMENT:\\n",
"COMMENT:\t\t\tMin\\:\t\t",
"GPRINT:UteMin:MIN:%6.1lf",
"GPRINT:mintimeout:(%d/%m %H\\:%M):strftime",
"COMMENT:\t\t\t\tMin\\:\t\t",
"GPRINT:InneMin:MIN:%6.1lf",
"GPRINT:mintimein:(%d/%m %H\\:%M):strftime",
"COMMENT:\\n",
