Hej.
Jag är newbie på Linux.
Köpte en raspberry pi (senaste), installerade deras nyaste mjukvara (noobs).
Allt fungerade som det skulle.
Sedan skulle jag installera owfs på detta med wikin ( http://wiki.temperatur.nu/index.php/OWF ... asperry_Pi), där gick det åt pipan.
Vad jag förstår har NOOBS nyare program än vad wikin är skriven för.
Vad gör jag för fel och hur kan jag göra för att komma vidare?
pi@raspberrypi ~ $ sudo apt-get update
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Get:1 http://mirrordirector.raspbian.org wheezy Release.gpg [490 B]
Get:2 http://mirrordirector.raspbian.org wheezy Release [14.4 kB]
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Get:3 http://mirrordirector.raspbian.org wheezy/main armhf Packages [7,413 kB]
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 7,428 kB in 53s (139 kB/s)
Reading package lists... Done
pi@raspberrypi ~ $ sudo apt-get install automake autoconf autotools-dev gcc-4.7 libtool libusb-dev libfuse-dev swig python2.6/dev php5/dev i2c-tools
Building dependency tree
Reading state information... Done
E: Release 'dev' for 'python2.6' was not found
E: Release 'dev' for 'php5' was not found
pi@raspberrypi ~ $ cd /usr/src
pi@raspberrypi /usr/src $ sudo wget -0 owfs-latest.tar.gz http://sourceforge.net/projects/owfs/fi ... t/download
wget: invalid option -- '0'
Usage: wget [OPTION]... ...
När jag kommer vidare på detta ska ... index.html.
