Hjälp med två temperaturer / grafer
ante
Inlägg av ante »
Ja vad säger man, jag får inte till det med två temperaturer / grafer, det är bara att erkänna :oops: . Fungerar utmärkt med en graf efter installation mha wikin. Har läst otaliga trådar men har inte lyckats hitta vad jag gör fel.
bifogar create_rrd.sh, get_temp.sh och graph_temp.pl
#!/bin/bash
# Script to create rrd-file
# 24h with 2,5 min resolution
# 7d with 5 min resolution
# 1y with 10 min resolution
# 20y with 1h resolution
directory="/home/pi/rrddata/"
RRDDataFileOut="outside_temp.rrd"
RRDDataFileIn="inside_temp.rrd"
# Check i file already exists
then
        echo "Creating RRDtool DB for outside temp sensor"
                 --step 150 \
                 DS:outsidetemp:GAUGE:300:-50:60 \
                 DS:insidetemp:GAUGE:300:-50:60 \
                 RRA:AVERAGE:0.5:1:576 \
                 RRA:AVERAGE:0.5:2:2016 \
                 RRA:AVERAGE:0.5:4:52560 \
                 RRA:AVERAGE:0.5:24:175200 \
                 RRA:MAX:0.5:1:5760 \
                 RRA:MAX:0.5:2:2016 \
                 RRA:MAX:0.5:4:52560 \
                 RRA:MAX:0.5:24:175200 \
                 RRA:MIN:0.5:1:5760 \
                 RRA:MIN:0.5:2:2016 \
                 RRA:MIN:0.5:4:52560 \
                 RRA:MIN:0.5:24:175200
        echo "Done!"
else
fi
#!/bin/bash
OutsideTempSensor="10.27AD18020800"
InsideTempSensor="10.407D18020800"
RRDDataDirectory="/home/pi/rrddata/"
# Get temps form OWFS
OutsideTemp=`cat /mnt/1wire/$OutsideTempSensor/temperature|sed -e s/" "//g|awk $
sleep 2;
IndoorTemp=`cat /mnt/1wire/$InsideTempSensor/temperature|sed -e s/" "//g|awk '{$
#Update RRD database
rrdtool update $RRDDataDirectory$RRDDataFile N:$OutsideTemp
sleep 5;
rrdtool update $RRDDataDirectory$RRDDataFileIn N:$InsideTemp
echo $OutsideTemp
echo $InsideTemp
#!/usr/bin/perl
use RRDs;
my $cur_time = time();
my $start_time = $cur_time - 86400;     # set end time to 24 hours ago
RRDs::graph "/var/www/graph_temp.png",
                        "--start= $start_time",
                        "--end= $cur_time",
                        "--title= Temp ute",
                        "--height= 300",
                        "--width= 500",
                        "--vertical-label= °C",
                "DEF:OutsideTemp=/home/pi/rrddata/outside_temp.rrd:outsidetemp:$
                "DEF:InsideTemp=/home/pi/rrddata/inside_temp.rrd:insidetemp:AVE$
                        "COMMENT:\t\t\t\tNu     Medel    Max    Min\\n",
                        "HRULE:0#0000FF",
              "LINE2:OutsideTemp#0000FF:Ute\t\t\t",
                        "GPRINT:OutsideTemp:LAST:%6.1lf",
                        "GPRINT:OutsideTemp:AVERAGE:%6.1lf",
                        "GPRINT:OutsideTemp:MAX:%6.1lf",
                        "GPRINT:OutsideTemp:MIN:%6.1lf\\n";
                        "HRULE:18#FFFF00",
              "LINE2:InsideTemp#00FF00:Inne\t\t",
                        "GPRINT:InsideTemp:LAST:%6.1lf",
                        "GPRINT:InsideTemp:AVERAGE:%6.1lf",
                        "GPRINT:InsideTemp:MAX:%6.1lf",
                        "GPRINT:InsideTemp:MIN:%6.1lf\\n";
my $err=RRDs::error;
print "Done!\n"
NiclasF
Re: Hjälp med två temperaturer / grafer
Inlägg av NiclasF »
I create_rrd.sh så definierar du ju aldrig $ filename.
Sent from my GT-I9305 using Tapatalk
NiclasF
Inlägg av NiclasF »
Liknande fel i get_temp.sh. Du uppdaterar aldrig RRDDataFileOut, bara RRDDataFile.
ante
Inlägg av ante »
NiclasF skrev:I create_rrd.sh så definierar du ju aldrig $ filename.
Okej,
Kan man då skriva två filename?
Så här?
filename="outside_temp.rrd"
filename="inside_temp.rrd"
Tack för snabbt svar
Förresten fin hemsida du har, eller är inte hemkoll.nu din sida?
CirruZZ
Master Moderator
Inlägg av CirruZZ »
Hur ser filerna ut nu?
ante
Inlägg av ante »
CirruZZ skrev:Hur ser filerna ut nu?
Öööööhhh, vilka filer? :oops:
NiclasF
Inlägg av NiclasF »
Inte min sida. Min sida dyker upp här inom kort, http://foogadget.tictail.com
Jag tycker att du ska ha en rrd per sensor. Gör om create_rrd.sh till att göra det.
Uppdatera sedan get_temp.sh till att uppdatera även RRDDataFileOut.
Sen skulle det kunna fungera.
NiclasF
Inlägg av NiclasF »
Prova det här scriptet för att skapa databaserna,
OBS. Jag har inte testat detta själv.
#!/bin/bash
# Check if file already exists
if [ ! -f "$directory$RRDDataFileOut" ]
then
        rrdtool create $directory$RRDDataFileOut \
                 --step 150 \
        echo "Out Done!"
else
        echo $directory$RRDDataFileOut" already exists, delete it first."
fi
if [ ! -f "$directory$RRDDataFileIn" ]
then
        echo "Creating RRDtool DB for inside temp sensor"
        rrdtool create $directory$RRDDataFileIn \
                 --step 150 \
        echo "In Done!"
else
        echo $directory$RRDDataFileIn" already exists, delete it first."
fi
ante
Inlägg av ante »
NiclasF skrev:Inte min sida. Min sida dyker upp här inom kort, http://foogadget.tictail.com
Hmm, hur göra detta? Kan jag dubbla det jag har i create_rrd.sh och sedan ändra outside till inside osv?
NiclasF
Inlägg av NiclasF »
Testa sedan den här get_temp.sh
#!/bin/bash
sleep 2;
rrdtool update $RRDDataDirectory$RRDDataFileOut N:$OutsideTemp
sleep 5;
echo $OutsideTemp
echo $InsideTemp
NiclasF
Inlägg av NiclasF »
Och sista scriptet som genererar grafer graph_temp.sh
#!/usr/bin/perl
use RRDs;
                        "--end= $cur_time",
                        "--height= 300",
                        "--width= 500",
                        "HRULE:0#0000FF",
                        "HRULE:18#FFFF00",
print "Done!\n"
ante
Inlägg av ante »
Är det nått mer jag ska göra? för det funkar inte?
pi@raspberrypi ~/rrddata $ ls -al
total 16476
drwxr-xr-x 2 root root    4096 Nov 18 20:45 .
drwxr-xr-x 6 pi   pi      4096 Nov 18 09:43 ..
-rwxr-xr-x 1 root root    2054 Nov 18 20:35 create_rrd.sh
-rw-r--r-- 1 root root 5614104 Nov 18 20:23 DS:outsidetemp:GAUGE:300:-50:60
-rw-r--r-- 1 root root 5614104 Nov 18 20:43 inside_temp.rrd
-rw-r--r-- 1 root root 5614104 Nov 18 20:38 outside_temp.rrd
Konstig fil den där DS:......
NiclasF
Inlägg av NiclasF »
Ta bort alla filer i rrddata och börja om.
NiclasF
Inlägg av NiclasF »
Anledningen till att du ska ta bort filerna är att jag kan se att det är olika tidsstämplar på alla filerna. Det ska åtminstone vara samma datumstämpel på rrd-filerna om du kör mitt script för att skapa rrd-databaserna, annars är det något konstigt.
Kopiera scriptet för att skapa databasen och lägg det i en ny fil som heter create_rrd.sh och gör det exekverbart,
$ chmod 755 create_rrd.sh
Kör sedan skriptet,
$ ./create_rrd.sh
ante
Inlägg av ante »
Fixat, tyvärr funkar det inte iaf
Nu vart de ordning i rrddata
total 10988
drwxr-xr-x 2 root root    4096 Nov 19 12:26 .
-rwxr-xr-x 1 root root    2054 Nov 19 12:25 create_rrd.sh
-rw-r--r-- 1 root root 5614104 Nov 19 12:26 inside_temp.rrd
-rw-r--r-- 1 root root 5614104 Nov 19 12:26 outside_temp.rrd
