Har skapat databasen så här:
    #!/bin/bash
    # Script to create rrd-file
    # 24h with 2,5 min resolution
    # 7d with 5 min resolution
    # 1y with 10 min resolution
    # 20y with 1h resolution
    directory="/home/pi/temp/rrddata/"
    filename="domoticz_temp.rrd"
    # Check i file already exists
    then
            echo "Creating RRDtool DB for outside temp sensor"
                     --step 120 \
                     DS:probe:GAUGE:120:-50:60 \
                     DS:xxxx1:GAUGE:120:-50:60 \
                     DS:vardagsrum:GAUGE:120:-50:60 \
                     RRA:AVERAGE:0.5:1:576 \
                     RRA:AVERAGE:0.5:2:2016 \
                     RRA:AVERAGE:0.5:4:52560 \
                     RRA:AVERAGE:0.5:24:175200 \
                     RRA:MAX:0.5:1:5760 \
                     RRA:MAX:0.5:2:2016 \
                     RRA:MAX:0.5:4:52560 \
                     RRA:MAX:0.5:24:175200 \
                     RRA:MIN:0.5:1:5760 \
                     RRA:MIN:0.5:2:2016 \
                     RRA:MIN:0.5:4:52560 \
                     RRA:MIN:0.5:24:175200
            echo "Done!"
    else
    fiKod: Markera allt
    #!/bin/bash
    rrdtool update /home/pi/temp/rrddata/domoticz_temp.rrd --template probe N:`head -n 1 </home/pi/temp/output/temp_probe.txt`
Koden för att skapa grafer:
    #!/bin/bash
    rrdtool graph /home/pi/temp/output/img/test/hour.png \
    -w 697 -h 287 -a PNG \
    --slope-mode \
    --start -6h --end now \
    --vertical-label "Last 6 hour temperature" \
    DEF:probe=/home/pi/temp/rrddata/domoticz_temp.rrd:probe:AVERAGE \
    DEF:xxxx1=/home/pi/temp/rrddata/domoticz_temp.rrd:xxxx1:AVERAGE \
    DEF:vardagsrum=/home/pi/temp/rrddata/domoticz_temp.rrd:vardagsrum:AVERAGE \
    COMMENT:"  Location       Min        Max       Senaste\l" \
    LINE1:probe#ff0000:"Utetemp" \
    LINE1:0#ff0000: \
    GPRINT:probe:MIN:"    %5.1lf"  \
    GPRINT:probe:MAX:"     %5.1lf"  \
    GPRINT:probe:LAST:"     %5.1lf\n"  \
    LINE1:xxxx1#00ff00:"Xxxx1" \
    LINE1:0#00ff00: \
    LINE1:vardagsrum#0000ff:"vardagsrum" \
    LINE1:0#0000ff: \
    GPRINT:probe:LAST:"     %5.1lf\n"  \Har provat att göra så här men då blir grafen helt tokig/korrupt. Vad har jag missat??
Hoppas det finns någon kunnig människa här inne som kan hjälpa till.
        #!/bin/bash
        rrdtool update /home/pi/temp/rrddata/domoticz_temp.rrd --template xxxx1 N:`head -n 1 </home/pi/temp/output/temp_xxxx1.txt`
 . Hur gör jag detta i ETT anrop?
