CONNECT: fuse mount point: /mnt/1wire
CALL: PARSENAME path=[]
CONNECT: Adapter found: 001/005
DEFAULT: Opened USB DS9490 adapter at 001/005.
DATA: DS9490_setup_adapter: done (ret=0)
DEBUG: Start of directory path= device=00 00 00 00 00 00 00 00
DEBUG: Selecting a path (and device) path= SN=00 00 00 00 00 00 00 00 last path=00 00 00 00 00 00 00 00
DEBUG: Clearing root branch
DATA: DS9490_reset
DATA: DS9490_getstatus: (HAVE_USB_INTERRUPT_READ) error reading ret=-110
DATA: DS9490_reset: ok
DATA: DS9490_getstatus: (no HAVE_USB_INTERRUPT_READ) error reading ret=-110
DATA: USBsendback control problem ret=-5
DEBUG: Transaction send = -5
DATA: BUS_first failed during connect [001/005] (Probably non-DS9490 device and empty bus).
DEBUG: fuse_mnt_opt=[(null)]
DEBUG: fuse_open_opt=[(null)]
unique: 1, opcode: INIT (26), nodeid: 0, insize: 56
INIT: 7.9
flags=0x0000003b
max_readahead=0x00020000
INIT: 7.8
flags=0x00000001
max_write=0x00020000
unique: 1, error: 0 (Success), outsize: 40
unique: 2, opcode: LOOKUP (1), nodeid: 1, insize: 47
LOOKUP /.Trash
CALL: FSTAT path=/.Trash
CALL: PARSENAME path=[/.Trash]
DEBUG: ParsedName_destroy /.Trash
unique: 2, error: -2 (No such file or directory), outsize: 16
unique: 3, opcode: LOOKUP (1), nodeid: 1, insize: 52
LOOKUP /.Trash-1000
CALL: FSTAT path=/.Trash-1000
CALL: PARSENAME path=[/.Trash-1000]
DEBUG: ParsedName_destroy /.Trash-1000
unique: 3, error: -2 (No such file or directory), outsize: 16
unique: 4, opcode: LOOKUP (1), nodeid: 1, insize: 47
LOOKUP /.Trash
unique: 4, error: -2 (No such file or directory), outsize: 16
unique: 5, opcode: LOOKUP (1), nodeid: 1, insize: 52
LOOKUP /.Trash-1000
unique: 5, error: -2 (No such file or directory), outsize: 16
^C Bryter här för det blir inge mer......
DEBUG: owfs: ow_exit(0)
CALL: Starting Library cleanup
CALL: Clear Cache
CALL: Closing input devices
CONNECT: Closed USB DS9490 adapter at 001/005. ret=0
CALL: Closing outout devices
CALL: Finished Library cleanup
Ok tack för tipset!pixi skrev:Jag upptäckte att den versionen som guiden handlar om inte stödjer DS2413 fullt ut, så jag uppdaterade till 2.7p17 och dom problemen var ur världen
Kanske skall byta version på owfs i guiden???
/Andreas H
