Module configuration:
owlib is enabled
owshell is enabled
owfs is DISABLED
owhttpd is enabled
owftpd is enabled
owserver is enabled
ownet is enabled
ownetlib is enabled
owtap is enabled
owside is enabled
owmon is enabled
owcapi is enabled
swig is enabled
owperl is enabled
owphp is DISABLED
owpython is enabled
owtcl is DISABLED
checking if owfs is enabled... auto (default)
checking fuse.h usability... no
checking fuse.h presence... no
checking for fuse.h... no
configure: WARNING:
Can't find fuse.h - Add the search path with --with-fuseinclude
configure: WARNING: Install FUSE-2.2 or later to enable owfs - download it from http://fuse.sourceforge.net/
configure: WARNING: OWFS is disabled because fuse.h is not found.Kod: Markera allt
fuse-libs-2.8.1-4.fc12.x86_64
fuse-2.8.1-4.fc12.x86_64
gvfs-fuse-1.4.3-7.fc12.x86_64
/usr/include/linux/fuse.h
/usr/src/kernels/2.6.32.10-90.fc12.x86_64/include/linux/fuse.h
/usr/src/kernels/2.6.32.11-99.fc12.x86_64/include/linux/fuse.h
/usr/src/kernels/2.6.32.12-115.fc12.x86_64/include/linux/fuse.h
Could not open the USB adapter. Is there a problem with permissions?
DEFAULT: ow_ds9490.c:DS9490_detect(311) Could not open the USB adapter. Is there a problem with permissions?
DEFAULT: owlib.c:SetupInboundConnections(175) Cannot open USB adapter
