Har tänkt använda en ljusensor jag köpt och kopplat in i mitt 1-wire nät.
Värdena lagras i en MySQL databas.
Jag vill kunna sätta upp en kontroll som kollar ljuset och som vid "mörkt" tänder lampor.
Men hittar inget bra sätt att slå på/av plugwise circles, är det som vet hur man gör ?
Jag kör mina plugwise i Windows, senaste FW samt senaste source.
Skall kolla din länk.....
edit: din länk verkar bara funka om man kör linux.och det gör jag bara på mitt 1-wire nät.
Mailade plugwise, fick svar på 10 minuter, kanon support måste jag säga.
Så här skrev de:
We are glad to hear that you are happy using our product. We highly encourage users to experiment with our products, and to combine the data and switching capabilities in setups that also include other measurement devices. However, as you might understand, we cannot provide helpdesk support for these installations. Still our R&D department has written a document that I have attached to this e-mail and that describes a communication protocol over a web server that can be used with our system. I hope you find the answers to your questions in this document.
An easier solution to your question can be achieved using our own wireless Plugwise ZigBee-enabled light sensor, the Scan. The Scan can switch Circles based on lighting changes and can be set up via Plugwise Source. The lighting data from the Scan is accessible via Source as well.
