Sida 1 av 3
Problem med Luftfuktighetsmätare [Version 2]
Postat: 05 nov 2012, 18:14
av linuxprofessor
Jag har nu kopplat all utrustning i min nya OW-SERVER-ENET2, alla prober fungerar utom Luftfuktighetsmätare [Version 2].
Jag har bifogat en skärmdump. Är problemet att den inte är kompatibel eller har min probe gått sönder?
Screen Shot 2012-11-05 at 17.13.32 .png (23 KiB) Visad 9619 gånger
Re: Problem med Luftfuktighetsmätare [Version 2]
Postat: 05 nov 2012, 20:32
Intressant. Det där fenomenet har jag inte sett förut.
Långa kablar? Testat att spänningsmata sensorn?
Postat: 05 nov 2012, 21:57
Jag skickade mail till tillverkaren...
Could you have them check their XML file? If it has reasonable data, please have them clear their cache. I'd like to know what browser & version number they have. I'd like them to try a different browser if clearing the cache doesn't fix the problem.
If the XML file also gives this odd information, please ignore the browser related questions above. I'd like to have more information on the circuit assuming display issues does not prove to be the problem. The "0" readings make me suspect none of the conversions are being performed. I think we will want them to perform a few low level commands. It might let us know if there is something buggy in the DS2438 polling code in the OW-SERVER, or if we need to look for external factors. I will get a example for polling the DS2438 with the low level commands posted online.
FYI, another possible cause would be if they are using the socket connection immediately once the OW-SERVER boots up. It could prevent the temp, VAD, VDD, and VSense from being polled.
Så 1:
Kolla XML-filen, ser den ok ut?
Postat: 06 nov 2012, 07:24
av linuxprofessor
<owd_DS2438 Description="Smart battery monitor">
<Name>DS2438</Name>
<Family>26</Family>
<ROMId>300000013F3A1D26</ROMId>
<Health>7</Health>
<Channel>1</Channel>
<RawData>
00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
</RawData>
<PrimaryValue>0.0000 Deg C</PrimaryValue>
<Temperature Units="Centigrade">0.0000</Temperature>
<Vdd Units="Volts">0.000000</Vdd>
<Vad Units="Volts">0.000000</Vad>
<Vsense Units="Millivolts">0.000000</Vsense>
<Humidity Units="PercentRelativeHumidity">-9223372036854775808.08</Humidity>
</owd_DS2438>
så ser det ut i XML-filen. har även hämtat ut datan via SNMP, samma problem där. kabeln är 1 meter lång utan några förgreningar eller liknande.
har testat safari och chrome under OS X, samt Firefox under Linux. ser likadant ut överallt.
fler idéer? =)
jag tar med luftfuktighetsmätaren till jobbet idag och testar den med en USB-1-wire-sticka för att förhoppningsvis kunna bestämma problemet till proben eller OW-servern.
Postat: 06 nov 2012, 09:54
av linuxprofessor
ovan har jag nu testat min luftfuktighetsmätare via en USB-1wire-sticka och den fungerar alldeles utmärkt. problemet ligger alltså i OW-servern.
Postat: 06 nov 2012, 19:00
Tillverkaren ska återkomma med förslag på hur vi går vidare.
Postat: 07 nov 2012, 22:59
Nu har Embedded skrivit en debugguide: https://eds.zendesk.com/entries/2235715 ... l-commands
1. Gå in under 1-wire Interface på din ENET-2
2. Kryssa i rutan "Enable" och klicka på Save.
3. Öppna ett en terminal (Ex Putty) och telnetta till din owservers ip på port 8080.
4. Följ debugguiden från embedded.
Enklast att följa är om du sätter RH-mätaren på port1. Sen ska det bara vara att byta ut romid mot ditt id.
Till en början är det bra om du kan köra kommandon under "Discover the Devices", "Read Status/Configuration Register", "Initiate Temperature Conversion", "Initiate the first voltage conversion" samt "Read the Results"
Pasta outputen du får här så bollar jag vidare med EDS.
Alternativt kan du ge mig tillgång till ip + port så kan jag eller tillverkaren debugga. (Även bra med tillgång till vanliga webinterfacet med).
Postat: 08 nov 2012, 09:15
av linuxprofessor
du kan komma åt min OW-server på http://82.197.227.105:45001 samt port 8080 http://82.197.227.105:45002
skickar lösenordet för admin i ett PM
Postat: 08 nov 2012, 16:59
JAg verkar inte komma åt port 8080 via 45002. Kan du dubbelkolla?
Postat: 08 nov 2012, 21:15
Vad händer om du sätter RH-mätaren ensam på en port?
Postat: 08 nov 2012, 21:38
Embedded vill att sensorerna skall vara fortsatt anslutna, men vi behöver åtkomst till port 8080 för att kunna felsöka.
Postat: 08 nov 2012, 22:01
av linuxprofessor
NU ska det fungera!
Postat: 08 nov 2012, 23:04
Hur långa kablar?
Testa att bygga jumpern på RH-mätaren för att på så sätt spänningsmata externt. Bygger så klart på att du har +5v vid sensorn.
Postat: 09 nov 2012, 08:56
av linuxprofessor
luftfuktighetsmätaren sitter på en gren från huvudkabeln som är ca 1 meter lång. har testat med den direkt in i OW-servern med bara 1 meter kabel, samma resultat. har även testat att sluta spänningsmatningsbygeln, inget resultat. hur är kontakteringen gjord på luftfuktighetsmätaren? gör det någon skillnad att sluta bygeln när man har den kopplad till OW-servern? jag märkte ingen skillnad när jag gjorde det iaf.
Postat: 09 nov 2012, 08:57
av linuxprofessor
kan även tillägga att luftfuktighetsmätaren fungerade utmärkt i den förra versionen av OW-server som jag använde. allt lutar alltså mot mjukvaruproblem i den nya versionen av OW-servern.
som grädde på moset har den nu slutat svara på HTTP-anrop. testat att starta om den, ingen skillnad. :x
