<?php
$wimgPath="wimg/"; //sökväg till vädersymboler
if (isset($_GET["temperaturAlias"]))
$temperaturAlias=$_GET["temperaturAlias"]; //Alias för den mätpunkt på temperatur.nu som skall användas som aktuell temperatur
else
$temperaturAlias="ekholmen";
if (isset($_GET["forecast"]))
$forecast=$_GET["forecast"]; //Sökväg på Yr.no till den prognos som skall användas Län/Ort
else
$forecast="Östergötland/Blästad";
$fontSize="28";
$file=fopen("http://www.temperatur.nu/termo/$temperaturAlias/temp.txt","r");
$temp=fgets($file);
fclose($file);
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=utf-8" >
<link href='http://fonts.googleapis.com/css?family=Exo' rel='stylesheet' type='text/css'>
<style>*{ font-family:Exo; font-size:<?php echo $fontSize;?>px;padding:0;margin:0; }
.header { font-size:5em;text-align:center;margin:0;font-weight:bold;}
</style>
<script>
var timerId; // current timer if started
var freq=300000; //uppdateringsintervall - millisekunder
var startDate = new Date();
var startTime = startDate.getTime();
function microseconds_elapsed ()
var date_now = new Date ();
var time_now = date_now.getTime ();
var seconds_elapsed = time_now - startTime;
return ( seconds_elapsed );
function doesConnectionExist() {
    var xhr = new XMLHttpRequest();
    var file = "http://www.temperatur.nu/favicon.ico";
    var randomNum = Math.round(Math.random() * 10000);
    xhr.open('HEAD', file + "?rand=" + randomNum, false);
    try {
        xhr.send();
        if (xhr.status >= 200 && xhr.status < 304) {
            return true;
        } else {
            return false;
    } catch (e) {
        return false;
function start() {
        update_time();
  timerId = setInterval(update_progress, 100);
 timerID2 = setInterval(update_time, 1000);
timerId3 = setInterval(function() {
        if (doesConnectionExist() == true)
                location.reload();
}, freq); /* 120000 ~> 2 minutes */
function update_progress() { //Progressbaren
        var progress=Math.round(microseconds_elapsed()*100/freq*100)/100;
        if (progress>99){
                document.getElementById("progress").style.backgroundColor = 'red';
                progress=100
        document.getElementById('progress').style.width = progress+"%";
function update_time(){
  var date = new Date();
  var hours = date.getHours()
  if (hours < 10) hours = '0'+hours
  var minutes = date.getMinutes()
  if (minutes < 10) minutes = '0'+minutes
 document.getElementById('time').innerHTML = hours+":"+minutes;
</script>
</head>
<body onload="start();">
<?/*<p style="text-align:center;margin:0;font-weight:bold;">Aktuell temperatur <?php echo $displayName;?></p>*/
?><center>
<table width=100%>
<tr><td class=header id=time><td width=50px;> <td class=header id=temp>
<? echo trim(str_replace(".",",",$temp));?>°C</div>
</table>
<img src="http://www.yr.no/place/Sverige/<?php echo $forecast;?>/meteogram.png" width=1000px>
<div style="font-size:0.4em;position:fixed;bottom:2px;  text-align:center;width: 100%; ">Väderprognos från yr.no | Presentation producerad av www.temperatur.nu</div>
</center>
<div id="progress" style="padding:0;margin:0;bottom:0px;position:fixed;height:2px;width:0%;background:#999;">
</body>
</html>Som många av de saker jag gör är det ett "proof of concept". Sidan är dum och kan inte visa annat än det som syns på bilden. Skulle inte vara några större problem att växla information om man trycker på skärmen, vet inte vad jag skulle visa bara...mg75 skrev: Man kanske kunde ha ett val mellan 2 eller 3 sidor beroende på vad man vill se.
Hur har du gjort, krävs det någon djupare kunskap i html?
