Jag försöker få min Qubino Flush shutter ZMNHOD att köra upp rullgardinen HELA vägen, inte bara halvvägs. Vad jag än testar så verkar jag inte kunna få den att gå längre än 11 sekunder. Det går utmärkt att sätta den till kortare tider, men när jag exempelvis försöker sätta den till 22s (220*0.1s) så stannar den likväl efter 11!
OpenHAB-loggen nedan antyder att parametern sätts som den ska. Någon som har några ideer?
2016-12-05 14:56:55.441 [DEBUG] [.z.i.config.ZWaveConfiguration] - Set parameter index '74' to '220'
2016-12-05 14:56:55.479 [DEBUG] [ZWaveConfigurationCommandClass] - NODE 3: Creating new message for application command CONFIGURATIONCMD_SET
2016-12-05 14:56:55.497 [DEBUG] [o.b.z.i.protocol.SerialMessage] - NODE 3: Creating empty message of class = SendData (0x13), type = Request (0x00)
2016-12-05 14:56:55.529 [DEBUG] [b.z.i.protocol.ZWaveController] - Callback ID = 157
2016-12-05 14:56:55.547 [DEBUG] [WaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-12-05 14:56:55.555 [DEBUG] [b.z.i.protocol.ZWaveController] - Enqueueing message. Queue length = 0
2016-12-05 14:56:55.575 [DEBUG] [ZWaveConfigurationCommandClass] - NODE 3: Creating new message for application command CONFIGURATIONCMD_GET
2016-12-05 14:56:55.590 [DEBUG] [o.b.z.i.protocol.SerialMessage] - NODE 3: Creating empty message of class = SendData (0x13), type = Request (0x00)
2016-12-05 14:56:55.555 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 03 06 70 04 4A 02 00 DC 25 9D BC
2016-12-05 14:56:55.616 [DEBUG] [b.z.i.protocol.ZWaveController] - Callback ID = 158
2016-12-05 14:56:55.642 [DEBUG] [b.z.i.protocol.ZWaveController] - Enqueueing message. Queue length = 1
2016-12-05 14:56:55.687 [DEBUG] [WaveController$ZWaveSendThread] - NODE 3: Sending REQUEST Message = 01 0D 00 13 03 06 70 04 4A 02 00 DC 25 9D BC
2016-12-05 14:56:55.724 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2016-12-05 14:56:55.811 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-12-05 14:56:55.815 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=0
2016-12-05 14:56:55.818 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2016-12-05 14:56:55.837 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2016-12-05 14:56:55.873 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
2016-12-05 14:56:55.905 [DEBUG] [b.z.i.p.s.SendDataMessageClass] - NODE 3: Sent Data successfully placed on stack.
2016-12-05 14:56:55.917 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 07 00 13 9D 00 00 02 74
2016-12-05 14:56:55.979 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-12-05 14:56:55.995 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=0
2016-12-05 14:56:56.027 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 9D 00 00 02 00 00 7A
2016-12-05 14:56:56.071 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 09 00 13 9D 00 00 02 00 00 7A
2016-12-05 14:56:56.133 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 9D 00 00 02
2016-12-05 14:56:56.149 [DEBUG] [b.z.i.p.s.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 157, Status = Transmission complete and ACK received(0)
2016-12-05 14:56:56.197 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 03 06 70 04 4A 02 00 DC
2016-12-05 14:56:56.253 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 9D 00 00 02
2016-12-05 14:56:56.271 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=SendData, cancelled=false
2016-12-05 14:56:56.285 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - transaction complete!
2016-12-05 14:56:56.296 [DEBUG] [b.z.i.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-12-05 14:56:56.325 [DEBUG] [.z.internal.ZWaveActiveBinding] - ZwaveIncomingEvent
2016-12-05 14:56:56.350 [DEBUG] [WaveController$ZWaveSendThread] - NODE 3: Response processed after 636ms/4437ms.
2016-12-05 14:56:56.354 [DEBUG] [WaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-12-05 14:56:56.428 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 03 03 70 05 4A 25 9E 62
2016-12-05 14:56:56.474 [DEBUG] [WaveController$ZWaveSendThread] - NODE 3: Sending REQUEST Message = 01 0A 00 13 03 03 70 05 4A 25 9E 62
2016-12-05 14:56:56.504 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2016-12-05 14:56:56.594 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-12-05 14:56:56.599 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2016-12-05 14:56:56.602 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=0
2016-12-05 14:56:56.620 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2016-12-05 14:56:56.659 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
2016-12-05 14:56:56.675 [DEBUG] [b.z.i.p.s.SendDataMessageClass] - NODE 3: Sent Data successfully placed on stack.
2016-12-05 14:56:56.700 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 07 00 13 9E 00 00 02 77
2016-12-05 14:56:56.805 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-12-05 14:56:56.820 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 9E 00 00 02 00 00 79
2016-12-05 14:56:56.806 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=0
2016-12-05 14:56:56.872 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 09 00 13 9E 00 00 02 00 00 79
2016-12-05 14:56:56.920 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 9E 00 00 02
2016-12-05 14:56:56.946 [DEBUG] [b.z.i.p.s.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 158, Status = Transmission complete and ACK received(0)
2016-12-05 14:56:56.973 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 03 03 70 05 4A
2016-12-05 14:56:57.039 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 9E 00 00 02
2016-12-05 14:56:57.042 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
2016-12-05 14:56:57.062 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 03 06 70 06 4A 02 00 DC 10
2016-12-05 14:56:57.189 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-12-05 14:56:57.195 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=0
2016-12-05 14:56:57.245 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 03 06 70 06 4A 02 00 DC 10
2016-12-05 14:56:57.293 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 03 06 70 06 4A 02 00 DC 10
2016-12-05 14:56:57.349 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 03 06 70 06 4A 02 00 DC
2016-12-05 14:56:57.366 [DEBUG] [ApplicationCommandMessageClass] - NODE 3: Application Command Request (ALIVE:DONE)
2016-12-05 14:56:57.399 [DEBUG] [ApplicationCommandMessageClass] - NODE 3: Incoming command class CONFIGURATION
2016-12-05 14:56:57.418 [DEBUG] [ZWaveConfigurationCommandClass] - NODE 3: Received Configuration Request
2016-12-05 14:56:57.431 [DEBUG] [ZWaveConfigurationCommandClass] - NODE 3: Node configuration report, parameter = 74, value = 220
