//Lars Karlander 2016
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include "ThingSpeak.h"
#include <OneWire.h>
#include <DallasTemperature.h>
#include <NewPing.h>
#define TRIGGER_PIN D1 // Pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN D2 //Pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 350 // Maximum distance we want t ping for (in cm).
#define ONE_WIRE_BUS D4 // 1-wire data pin for temp sensors
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
// NewPing setup of pins and maximum distance.
#define CNT 921 // Array for averaging sonar value
int d[CNT];
unsigned long looptime;
// Assign the addresses of 1-Wire temp sensors, max 6 sensors, 8 if no rssi or sonar.
// Missing sensor will give -127.00C reading
DeviceAddress Temp1 = { 0x28, 0x44, 0xC3, 0xAF, 0x06, 0x00, 0x00, 0x39 }; //-10cm
DeviceAddress Temp2 = { 0x28, 0x70, 0x18, 0xB1, 0x06, 0x00, 0x00, 0x0B }; //-30cm
DeviceAddress Temp3 = { 0x28, 0x49, 0xA9, 0xAF, 0x06, 0x00, 0x00, 0xDF }; //-60cm
DeviceAddress Temp4 = { 0x28, 0xA5, 0x9F, 0xAF, 0x06, 0x00, 0x00, 0x93 }; //-100cm
DeviceAddress Temp5 = { 0x28, 0x57, 0xEB, 0xAF, 0x06, 0x00, 0x00, 0xFD }; //-150cm
DeviceAddress Temp6 = { 0x28, 0x2D, 0xB0, 0xB0, 0x06, 0x00, 0x00, 0xED }; //-200cm
DeviceAddress Temp7 = { 0x28, 0x0E, 0xDA, 0xB0, 0x06, 0x00, 0x00, 0xAE };
unsigned long sleeptime =251000; //milliseconds
unsigned long myChannelNumber = 75712;
const char * myWriteAPIKey = "XXXXXXXXXXXXX";
WiFiClient client;
void setup() {
Serial.begin(9600);
Serial.println("Startar...");
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//reset saved settings
//wifiManager.resetSettings();
//set custom ip for portal
//wifiManager.setAPConfig(IPAddress(10,0,1,1),
IPAddress(10,0,1,1), IPAddress(255,255,255,0));
//fetches ssid and pass from eeprom and tries to connect
//if it does not connect it starts an access point with the specified name
wifiManager.autoConnect("NodeMCU-01-wifi-setup");
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
sensors.begin();
// set the resolution
sensors.setResolution(Temp1, 12);
sensors.setResolution(Temp2, 12);
sensors.setResolution(Temp3, 12);
sensors.setResolution(Temp4, 12);
sensors.setResolution(Temp5, 12);
sensors.setResolution(Temp6, 12);
ThingSpeak.begin(client);
void loop() {
looptime=millis(); // Kolla tiden för ett varv
int i;
long m;
long m2; //mean value from middle of array
int loopcount;
m2=0;
loopcount=0;
Serial.println("Start pinging!");
for(i=0; i<CNT; i++)
d[i] = (sonar.ping_cm());
delay (40);
loopcount=loopcount+1;
if (loopcount==40) {
Serial.print((i*100)/CNT);
Serial.print("% ");
loopcount=0;
} //end if 921 loops
Serial.println(" ");
Serial.println("Done pinging, start sorting");
sort(d,CNT);
Serial.println("Done sorting");
for(i=900; i<CNT-10; i++)
m2=m2+d[i];
// Serial.println(d[i]);
m2=m2/(CNT-910);
//Print Temperatures
Serial.println("Getting temperatures...");
sensors.requestTemperatures();
float t1 = sensors.getTempC(Temp1);
delay(50);
float t2 = sensors.getTempC(Temp2);
delay(50);
float t3 = sensors.getTempC(Temp3);
delay(50);
float t4 = sensors.getTempC(Temp4);
delay(50);
float t5 = sensors.getTempC(Temp5);
delay(50);
float t6 = sensors.getTempC(Temp6);
ThingSpeak.setField(1,t1);
ThingSpeak.setField(2,t2);
ThingSpeak.setField(3,t3);
ThingSpeak.setField(4,t4);
ThingSpeak.setField(5,t5);
ThingSpeak.setField(6,t6);
ThingSpeak.setField(7,m2); //average sonar reading in field 7
Serial.print("Temp 1 is: ");
Serial.print(t1);
Serial.println("C: ");
Serial.print("Temp 2 is: ");
Serial.print(t2);
Serial.print("Temp 3 is: ");
Serial.print(t3);
Serial.print("Temp 4 is: ");
Serial.print(t4);
Serial.print("Temp 5 is: ");
Serial.print(t5);
Serial.print("Temp 6 is: ");
Serial.print(t6);
Serial.println("");
Serial.print("Medel2, values cut:");
Serial.println(m2);
// print your WiFi IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("RSSI:");
Serial.println(rssi);
ThingSpeak.setField(8,rssi);
// Write the fields that you've set all at once.
ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
delay(sleeptime);
Serial.print("Looptime last loop ");
Serial.print((millis()-looptime)/1000);
Serial.print(" Seconds, and of that was ");
Serial.print(sleeptime/1000);
Serial.println(" seconds sleeptime, the rest pingtime");
void sort(int a[], int size) {
for(int i=0; i<(size-1); i++) {
for(int o=0;
o<(size-(i+1)); o++) {
if(a[o] > a[o+1]) {
int t = a[o];
a[o] = a[o+1];
a[o+1] = t;
}Kod: Markera allt
