I'm looking for a solution that allows me to keep the same style in my house.
I have Schneider exxact frames throughout the house. Some of these are physical switches, some are System Nexa WTE2 switches.
I'm slowly moving my house to zigbee and would like to find a solution that works.
On the back end, I'm running Home Assistant, with SmartThings as the gateway to the zigbee network.
For the virtual switches, it seems that Schender has the Wiser switch, but that seems quite locked down (and really expensive) and I have not found any information about getting it to work with SmartThings or Home Assistant. There are also references to a sunricher switch, SR-ZGP2801K4-DIM-G2, but that doesn't seem to exist any longer. Sunricher has the exact model that I would like - SR-ZGP2801K4-FOH-E, but is only Hue compatible. With Smart Things, Ikea, and Telldus (for 433Mhz compatibility), I am trying to reduce complexity, not add to it
On the physical side, I'm using Aqara T1 behind some of the switches, but space-wise, there is no way to put two of these behind a single switch (even getting one behind is extremely difficult).
Anybody have any ideas for either the physical or virtual switches?
