avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "C:\Users\81060582\AppData\Local\Temp\build65a5aca9c4640dedaaed4c90d50f288f.tmp/Xmas_lights_by_mnu_2EF.ino.hex"
avrdude: writing flash (6148 bytes):
Writing | ################################################## | 100% 1.77s
avrdude: 6148 bytes of flash written
avrdude: verifying flash memory against C:\Users\81060582\AppData\Local\Temp\build65a5aca9c4640dedaaed4c90d50f288f.tmp/Xmas_lights_by_mnu_2EF.ino.hex:
avrdude: load data flash data from input file C:\Users\81060582\AppData\Local\Temp\build65a5aca9c4640dedaaed4c90d50f288f.tmp/Xmas_lights_by_mnu_2EF.ino.hex:
avrdude: input file C:\Users\81060582\AppData\Local\Temp\build65a5aca9c4640dedaaed4c90d50f288f.tmp/Xmas_lights_by_mnu_2EF.ino.hex contains 6148 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.32s
avrdude: verifying ...
avrdude: 6148 bytes of flash verified
avrdude done. Thank you.
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the Uno and
Leonardo, it is attached to digital pin 13. If you're unsure what
pin the on-board LED is connected to on your Arduino model, check
the documentation at http://www.arduino.cc
This example code is in the public domain.
modified 8 May 2014
by Scott Fitzgerald
// the setup function runs once when you press reset or power the board
void setup() {
// initialize digital pin 13 as an output.
pinMode(13, OUTPUT);
// the loop function runs over and over again forever
void loop() {
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(5000); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
delay(1000); // wait for a second
elf98 skrev:Om du får ok när du programmerar så är den biten rätt.
Om det tänds lite dioder när du ansluter spännignsmatning är röd och blå kabel rätt (spänningsmatning.
Kan du ta kort på undersidan av kortet? Något är knas med gul och grön kabel och dess väg till nanon.
Jag klipper och löder om kontakterna så det bli rättelf98 skrev:Japp, du kan ha fått bakvänd slinga.
Bra att det fungerar. Vill du ha en adapter? eller löser du det ändå?
