avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.16
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "C:\Users\81060582\AppData\Local\Temp\build65a5aca9c4640dedaaed4c90d50f288f.tmp/Xmas_lights_by_mnu_2EF.ino.hex"
avrdude: writing flash (6148 bytes):
Writing | ################################################## | 100% 1.77s
avrdude: 6148 bytes of flash written
avrdude: verifying flash memory against C:\Users\81060582\AppData\Local\Temp\build65a5aca9c4640dedaaed4c90d50f288f.tmp/Xmas_lights_by_mnu_2EF.ino.hex:
avrdude: load data flash data from input file C:\Users\81060582\AppData\Local\Temp\build65a5aca9c4640dedaaed4c90d50f288f.tmp/Xmas_lights_by_mnu_2EF.ino.hex:
avrdude: input file C:\Users\81060582\AppData\Local\Temp\build65a5aca9c4640dedaaed4c90d50f288f.tmp/Xmas_lights_by_mnu_2EF.ino.hex contains 6148 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.32s
avrdude: verifying ...
avrdude: 6148 bytes of flash verified
avrdude done.  Thank you.
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the Uno and
  Leonardo, it is attached to digital pin 13. If you're unsure what
  pin the on-board LED is connected to on your Arduino model, check
  the documentation at http://www.arduino.cc
  This example code is in the public domain.
  modified 8 May 2014
  by Scott Fitzgerald
// the setup function runs once when you press reset or power the board
void setup() {
  // initialize digital pin 13 as an output.
  pinMode(13, OUTPUT);
// the loop function runs over and over again forever
void loop() {
  digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(5000);              // wait for a second
  digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
  delay(1000);              // wait for a second
}elf98 skrev:Om du får ok när du programmerar så är den biten rätt.
Om det tänds lite dioder när du ansluter spännignsmatning är röd och blå kabel rätt (spänningsmatning.
Kan du ta kort på undersidan av kortet? Något är knas med gul och grön kabel och dess väg till nanon.
Jag klipper och löder om kontakterna så det bli rättelf98 skrev:Japp, du kan ha fått bakvänd slinga.
Bra att det fungerar. Vill du ha en adapter? eller löser du det ändå?
