Har provat att ta bort och lägga till den i Domoticz, har provat att använda "HEAL" funktionen samt att jag gjort brytaten strömlös för att se om den reset:ar sig.
Bifogar utdrag ur loggen från Domoticz:
2016-05-24 21:06:59.162 OpenZWave: Starting...
2016-05-24 21:06:59.167 OpenZWave: Version: 1.3-614-gadf3467
2016-05-24 21:06:59.167 OpenZWave: using config in: /home/pi/dev-domoticz/Config/
2016-05-24 21:06:59.383 OpenZWave: Driver Ready
2016-05-24 21:06:59.383 OpenZWave: New Node added. HomeID: 3971991575, NodeID: 1 (0x01)
2016-05-24 21:06:59.385 OpenZWave: New Node added. HomeID: 3971991575, NodeID: 2 (0x02)
2016-05-24 21:06:59.386 OpenZWave: New Node added. HomeID: 3971991575, NodeID: 3 (0x03)
2016-05-24 21:06:59.387 OpenZWave: New Node added. HomeID: 3971991575, NodeID: 4 (0x04)
2016-05-24 21:06:59.501 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2016-05-24 21:06:59.504 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2016-05-24 21:06:59.505 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2016-05-24 21:06:59.540 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-05-24 21:07:01.665 Hardware Monitor: Fetching data (System sensors)
2016-05-24 21:07:05.139 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-05-24 21:07:53.058 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-05-24 21:07:53.060 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-05-24 21:07:53.061 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2016-05-24 21:07:53.063 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2016-05-24 21:07:53.064 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Unknown, Instance: 1
2016-05-24 21:07:58.769 OpenZWave: Received Node Dead notification from HomeID: 3971991575, NodeID: 3 (0x03)
2016-05-24 21:07:58.766 (Zwave) Lighting 2 (V Hall Nere)
2016-05-24 21:08:03.633 Hardware Monitor: Fetching data (System sensors)
NodeID:3 är brytaren.
Skall jag tolka detta tillsammans med de åtgärder som jag redan gjort att brytaren är trasig?
Hälsn.
Stefan
